- Joined
- Feb 28, 2010
- Messages
- 1,663
Hello fellow oil researchers, just have some questions that I would like to get answered. Did some searching and the posts are starting to get kinda old and just wanted to see if anything has changed.
First.
Point Spread. I was always taught to not use an oil with a "large" viscosity point spread. Mainly due to all the junk that has to be added to make it so "broad" range can actually cause deposit formations on things like turbo journals and such. Since I am running a 0w40 Oil in my car, that is a pretty hefty 40 pt spread. I realize you buy an oil for what its spec'd for, but this is just something I am curious about when looking at an oil that meets a spec. For my application we will use VW 502/504. If I can get a spec'd oil that is a 5w30, or a 0w30 vs a 5w40 or a 0w40 would the lower point spread be better? Better in that it has less stuff in it to make the spread, and that "stuff" causing deposits on hot spots of the engine like turbo journals.
Question 2.
I see a switch in technology in oil. Seems Boron, the new Moly out (I forget the name of it, but its like a "nano" type Moly) vs more old school stuff like Zinc and Phosphorous. Good Examples of opposites. GC 0w30 and M1 0w40. Both are loved on this site but have totally different additive packs. You look at Redline too full of moly (not sure what kind) tons of calcium and ZPPD. I am just naming a few as examples. Since I am no chemist, are there certain "elements" that are known to be better for wear vs another. If an engine is "tough" on oil, or has potential to wear out an oil fast, do some elements, hold up better to fuel dilution and acids better than others to prevent wear? If so, which ones do you really want to have in the oil you choose?
I realize these topics may have been brought up many times, but most I have read are over 10 years old and we all know how much oils have changed over 10 yrs. Just wanted more recent info from the folks in the know.
Thanks for your time as always.
Jeff
First.
Question 2.
Jeff
