I liked the fact it had 6 engines. That’s two more than 4. Hope they build another.
I think the cost of repowering while simultaneously rebuilding and/or finishing the airframe may be too tall a task.If they build a new one could it use the 777 size engines and only need 4 engines ? Pondering.
On existing airframes that is a major undertaking. The load paths in and through the wings are already designed and built. You'd essentially be redesigning the entire aircraft. Plus there is wiring and the entire fuel system would have to be reconfigured.If they build a new one could it use the 777 size engines and only need 4 engines ? Pondering.
It most certainly does, that was one of the reasons the Air Force gave in ultimately decided against four engines. The pylons would require redesign and it also affected the attachment point loading in the wing.and going from 8 to 4 on the B-52 would likely be simpler, doesn't change the load paths
Fog of war. Here's an overhead photo of the hanger it was in.Why no photos of destroyed aircraft ?
I would imagine a GE CF6-80C Boeing/Airbus spec(still made for the 767 and A330ceo), PW4062 or the Rolls-Royce RB211-524(or even the Trent series) could be adapted along with Western(GE/Honeywell/Rockwell Collins/Thales/Safran) avionics if the An-224 was to be remade.If they build a new one could it use the 777 size engines and only need 4 engines ? Pondering.
Did you not see the pic I posted above with the tail on fire and the smoke coming out of the hangar? Just want to make sure if my posts are visible.Be skeptical of anything you hear from that area. Why no pics yet of the "destroyed" An-225?
There are several varieties of those Russian mammoths - not sure if I've seen the Antonov 225, but have two huge beasts of that sort, both around 2006. Out with buddies for our lunchtime walk at work and saw this huge aircraft in profile, heading N toward the airport. It looked somewhat like the Space Shuttle from the side, with it unusual aspect ratio. Looked incredibly slow, but that was because it was so huge it seemed to take a long time to travel its own length.That's too bad. I saw it when it was in Winnipeg about 20-25 years ago picking up agricultural equipment.
