quote:Are you trying to achieve better MPGs or prove thin oil can protect.....or both?
Originally posted by G-Man II: I changed the oil in my Chrysler to Pennzoil 5w20 this morning. No unusual noises coming from the engine. hehe In 3000 miles we'll see how it does.
quote:I'm not trying to prove anything. I've been impressed with the UOAs I've seen from the 5w20 oils. I've done UOAs with my Chrysler on both Mobil 1 10w30 and Castrol 0w30. I want to see how 5w20 does in my engine since it isn't spec'd for 5w20. I chose Pennzoil because I believe it to be the best built "conventional" 5w20 you can by: 40% Group III and 60% Group II+, more moly than Mobil 1, just as much boron as Mobil 1, no magnesium, and lots of calcium. If the 3000 mile wear numbers are as good as or better than Mobil 1 and/or GC, I'll probably continue to use it. If not, I'll probably go with Pennzoil 5w30 High Mileage.
Originally posted by Last_Z: Are you trying to achieve better MPGs or prove thin oil can protect.....or both?
quote:No, up above where I said "If the 3000 mile wear numbers are as good as or better than Mobil 1 and/or GC, I'll probably continue to use it" I meant I was just going to guess at the wear numbers without doing a UOA.
Originally posted by Cutehumor: are you going to do a UOA to see what's going on?
quote:Click here for the explanation.
Originally posted by Last_Z: What happened to the GC stuff? I thought you had settled for it!? Did something go wrong?
quote:G-Man, Lighten up dude....I think a beer is in order!
Originally posted by G-Man II:quote:No, up above where I said "If the 3000 mile wear numbers are as good as or better than Mobil 1 and/or GC, I'll probably continue to use it" I meant I was just going to guess at the wear numbers without doing a UOA.
Originally posted by Cutehumor: are you going to do a UOA to see what's going on?![]()
quote:I disagree. I think the experiment means just as much as testing ANY oil during this time of the season. As for driving styles, I'm not going to drive my car any harsher than I normally would, nor am I going to baby it. If the 3000 mile results are good, I will run the 5w20 through the summer and see what those results look like.
Originally posted by R Stuart: This experiment means nothing during this time of the season in that engine . Try the heat of summer with that 20 weight in this engine after sticking your foot in the throttle to your posted 6500 rpm redline a few times similating real world passing gear when needed then analise the oil .
quote:I had planned to run it an entire year. The oil itself had only been in the car since the end of October and had about 2400 miles on it.
Originally posted by Lubricious: After running that German Castrol an entire year and not being able to learn anything from the results is an cruel misfortune. The important data that was lost to this community and this forum board was of priceless value.
quote:Yip, check out Wal-Mart. Mine only has Motorcraft, Pennzoil, and Castrol. Ask and usually Autozone or Advance will stock whatever you want, no problem.
Originally posted by G-Man II:quote:Welcome to the forum. I got the Pennzoil 5w20 at Wal-Mart. They have it in 5qt jugs as well as single qt bottles. You can also get Motorcraft 5w20, Castrol 5w20, and Valvoline 5w20 at Wal-Mart. They also have Mobil 1 0w20 and Pennzoil Synthetic 5w20.
Originally posted by Kalbo: Does anyone know who carries (retail store or Manufacturer) a supply 5w-20 oils?
quote:I think the M1 5-30 is great to run in this engine also. Not to worry.
Originally posted by Kalbo: I have a 2003 Honda Accord LX 4-cyl. Honda specifies 5w-20 motor oil. None of the Auto Supply stores in my area carry 5w-20 of any kind (except the Honda dealer of course, I have never liked "Honda Oil" reports I have read have always rated low). I'm running Mobil 1 5w-30. Any problems with using a slightly higher viscosity oil like this than Honda recommends? Does anyone know who carries (retail store or Manufacturer) a supply 5w-20 oils? Thanks Paul
quote:I had planned to run it an entire year. The oil itself had only been in the car since the end of October and had about 2400 miles on it. Imagine the look of bewilderment on that mechanics face when he unscrewed the plug and saw the clear amber GC streaming out into the sump. Then when he looks at the oversized filter he just removed compared to the tiny AC Delco he must use as a replacement. Do you think he scratched his head?
