- Joined
- May 28, 2014
- Messages
- 2,261
I agree. I heard a late model Mustang last night that made the ground rumble. Can you imagine driving that all day?
I've got a Vortech supercharged mustang that'll drive you insane then
The Mustang turbo makes turbo sounds through the speaker system as you drive it.
I rented one and it was hilarous.
Axial or radial play in the turbo shaft is normal unless there is evidence of compressor wheel contact with the compressor housing. Do not compare turbocharger noises to other vehicles as part tolerances, engine calibrations, and other factors can cause sound characteristics to vary between otherwise similar vehicles. It is very rare for a turbo to have a problem without setting a diagnostic trouble code (DTC). Diagnostics should only be performed for turbocharger noise concerns if other symptoms are present in addition to the noise. The turbo should only be replaced if the pinpoint test for a DTC dire• Rattle noise at idle or during light load conditions
• Whine noise that will track with engine speed
• Whoosh noise on acceleration
• Noise with wastegate actuation (creak, squawk)
I really can't hear it on my Subaru 2.0 unless I go WOT (which is frequently ) Does the ecoboost have an indicator that shows the boost psi. I really like that feature.
So.....I am one that if I was gunna buy a turbo I need to at least hear it a little. Nope, in no way can you even dream of hearing it.
What are they doing technology wise to silence it, and what can a consumer do to louden it up a bit?
Please do not turn this into a war thread about turbo sound. I personally love it, others do not and cannot stand it. Completely understand both sides of the coin.
I installed a CAI or Cold Air Intake and it added that sound I am looking for. At first, I was hesitant, but upon research, I stumbled upon an article that made me realize it won’t be a bad decision since it is not just the sound that would be the benefit but that extra kick when you floor the pedal. The only thing is my gas mileage went up a bit because I enjoy the sound when I throttle it.
