Originally Posted by kschachn
Originally Posted by BlueOvalFitter
Try joining the fittings without the pipe dope and see how many leaks you will have. Report back with your findings then.
One would assume the dope allows the threads to engage without premature galling or welding, before an adequate metal-to-metal seal is made.
Try holding back 175 PSI with an uncontained liquid and see how it works. Report back with your findings then.
It has been done many of days in EXXON petro plant back in the day (80"s). What were you doing back then, just learning to crawl?
