Hello,
Would anyone happen to know what hole of the governor arm the linkage from the throttle plate should go in? Like an idiot, I pulled the carb off last night and made a mental note to remember where it went, but the carb fell off before I could notice. I have four holes on the top of the arm, none is showing wear or shiny metal that might give me a clue where it was. I looked at manuals online, most only show one hole.
Thanks in advance, I'm learning small engine repair by doing here. I'm at work, and the snowblower is at home, but I think it is a SK50. Vintage early 80's. I can provide the code tonight if needed.
On a related note - the fuel line I pulled off it is 7/32 ID but all the new fittings I see say they are 1/4. I need to replace the fuel shutoff. Is the smaller 7/32 hose to give compression around the 1/4 fitting, or do I have oddball fuel line on this thing?
Thanks!
Thanks!
