TBN Question
Australia
Hi all, I did a search, and could not find anything that may of answered my question, so sorry if it had been asked before. With the TBN rating of an oil, is there much difference in say a 10.5 to an oil that is 7.9? I'm asking because an oil I was currently using was 10.5, but now is only 7.9. And I want to know if this is reason enough to have a look elsewhere? I originally chose the oil because it out of all the ones I looked at had a high TBN, so I thought it would have a great detergency package. In petrol engines, would there be much noticeable difference in using a TBN of 10.5 as to one that is only 7.9? Also, I found out the oil doesn't use any Boron! A bit of Molly and a good amount of Zinc, but no Boron. It does however have near 3000ppm of calcium, but they have lowed the TBN to 7.9! Am I worrying over nothing?
Saskatchewan, Canada
If you are extending your OCI well beyond what's normal or recommended then there is cause for concern. But even at 7.9 that oil should go 5000 miles easy. So there's no great need to be alarmed. What kind of oil is this? 7.9 is high for a dino oil and low for a synthetic.
