Tap into high pressure side of engine oil.
I just got a bypass oil centrifuge for my 2017 Dodge Ram 6.7 Diesel. Where can I tap into the high pressure side of the oil line other than the top of the oil filter???
Maryland
You do realize that if you run some type of bypass oil filtration system that your oil pressure will go down.
