Our Gulfstream G550/650 will skid all 4 main tires if the brakes are held too long... We've done a number of max performance takeoff's. I brought my G-Tech along and it recorded 11.69 seconds 1/4 mile at 144 MPH. Rumor has it that 10 second 1/4 mile runs are possible if you hold the brakes longer. But risking $20K worth of tires is probably not smart.
If light, the G550/650 will climb at 45 degrees pitch up and still accelerate!
You airline guys might like the fact that normal climb in the G650ER is M0.87.
Looks like the reverse thrust is very effective. Nice looking airplane.
Most airline pilots do not get a chance to do any extreme short landing , hard braking type stuff because we carry passengers and they wouldn’t like it. We fly like limo drivers when possible.....gently.Some of the comments are saying that a stop like that would be extremely hard on the brakes and that it wouldn't normally be done except as a demonstration.
That's the Meggitt auto brake system in action. Dial in low, med or maximum. It's fly by wire, so you will notice the ailerons moving up upon touchdown, to help spoil lift, along with the spoilers. What you don't see is the tail position moves to maximize load on the main tires. On the highest setting, the plane will stop with incredible G force, there are claims that it peaks at 3G. It's very uncomfortable, even for those of us accustomed to race car brakes.Some of the comments are saying that a stop like that would be extremely hard on the brakes and that it wouldn't normally be done except as a demonstration.
More later on brakes and reverse thrust on the Airbus ( wife’s calling me to watch a movie ). Hint, reverse thrust is not very effective ( sounds like it should be ).
It’s like a sports car in the air and on the ground.That's the Meggitt auto brake system in action. Dial in low, med or maximum. It's fly by wire, so you will notice the ailerons moving up upon touchdown, to help spoil lift, along with the spoilers. What you don't see is the tail position moves to maximize load on the main tires. On the highest setting, the plane will stop with incredible G force, there are claims that it peaks at 3G. It's very uncomfortable, even for those of us accustomed to race car brakes.
We tried it a few times and that's enough.
The brakes are carbon/carbon and don't exhibit much wear per landing, regardless of how hard they are used. They last about 1500 landings, then require a spacer for an additional 1000 landings.
And, yes, it will make the first taxiway at many airports.
Aircraft ( Airbus anyways ) are more worried about brake temperature than how hard you put the brakes on due to “turn around” times ( 1 hour my company....but less if we came in late ) as they more you press , the hotter they get. The Airbus has Auto brakes ( low, medium for landing ) but a pilot can land with manual brakes if they choose ( depending on conditions ). Brake temperatures ( Airbus for this post ) can get very hot and cause a delay for take off ( unless that aircraft has optional brake fans ) because they cannot be more than 300 celcius and may have reached 450 celcius ( A321 ) after landing. That’s rare but it can be an operational concern in the Caribbean or in Las Vegas . As for brake wear, aircraft carbon brakes like it hot ( disc temperature ) as they experience less wear, up to a point ( 500 celcius or higher causes oxidation plus we have advise ramp personnel we have “hot brakes“ and advise maintenance ....never seen that ). On the Airbus , the least brake wear actually occurs after the “brakes hot” warning ( 300 c ) comes on and is about 450 c. If we landed on a long runway and hardly touched the brakes, we would actually be causing more wear because the brakes would be at a much lower temperature. Brake wear is also dependant on the number of brake pedal applications ( increased wear from more applications ). Thats why Autobrake is recommended for all landings because they apply one application and cause less wear. Taxiing on the ground also causes wear obviously but it’s worse than many think as pilots ( they try not to ) have to apply more brake applications ( allow plane to accelerate to 35 MPH THEN apply brakes to reduce speed to 10 MPH then allow it to accelerate to 35 MPH again and slow down and repeat this cycle until close to the gate to avoid too many applications which cause increased wear and heat ).Some of the comments are saying that a stop like that would be extremely hard on the brakes and that it wouldn't normally be done except as a demonstration.
Pilots approach differently how they will brake ( manual, Autobrake and what level ) , where they will plan on existing the runway and whether they will use reverse thrust. Personally, it shows me how well a pilot knows the plane when they brief it.
As for reverse thrust , it’s not very effective on the narrow body Airbus. I “never” use it unless the landing performance app on our iPads says we need it ( A321 on wet runway 7000 feet ). Airbus used ( before we had the app ) to say it reduced the landing distance 3% dry and 6% wet runway but now it’s not even that effective calculations wise. e.g If landing at KNSA ( 5700 ) it says the plane needs the same amount of runway, with or without reverse. Why use it if it’s not required, more noise, an extra 48 pounds of fuel every landing for nothing IIRC. It helps on the A321 with Wet runways.
I was not trying to make it about the Airbus but that’s the plane I fly and know very well. Hopefully I answered you question well enough.
About people trying to be able to fly who aren’t pilots ....look up Helios 522. The flight attendant was alive and made their way into the flight deck.....before it crashed IIRC.I'm more familiar with fictional accounts. Like a TV when I was a kid where somehow a kid had to be coached into landing a 747. Long story, but it was a sci-fi/time travel fantasy show where they end up on a 747, and eventually save future President Jimmy Carter from a hijacker. What I remember was the kid being yelled at by a pilot (brought to ATC) to absolutely stand on the pedals in order to brake really hard.
I watched it and a hijacker had released some sort of incapacitating gas, but the kid manages to get to the cockpit alone and closes the door behind and puts on the cockpit emergency air. I see that he was asked to just use the brakes but I didn't see any thrust reversers. It seems like NBC has these available free now. However, I understand that it may not be available in your country.
Watch Voyagers! Episode: All Fall Down - NBC.com
Watch All Fall Down (Season 1, Episode 18) of Voyagers! or get episode details on NBC.comwww.nbc.comPhineas spars with boxing legend Joe Louis in the hopes of preventing him from quitting his career; Jeffrey must land a 747 airplane after a hijacking - and future President Jimmy Carter is on board."Voyagers!" All Fall Down (TV Episode 1983) - IMDb
Directed by Ron Satlof. With Jon-Erik Hexum, Meeno Peluce, John Hancock, L.Q. Jones. In 1938, Jeffrey and Phineas must convince Joe Louis not to quit his rematch with Max Schmeling. They also save a doomed 747 aircraft that had future President Jimmy Carter on board in 1970.www.imdb.com
Hahahahaha, very well said. I kind of feel bad for the patient..... Hahahahahahaha.Can a passer-by walk in and save the patient?
Maybe. Not looking good for that patient.
Helios 522.
Flight Attendant Tried to Save Cypriot Plane
A flight attendant tried to save a Cypriot airliner that crashed near Athens earlier this year, wrestling with controls for at least 10 minutes before the Helios Airways flight...www.aviationpros.com
