Hi, I’ve been reading these forums for quite sometime now and I need some advice as I’m still a little confused. I have an antique (kinda) tractor with a Kohler Magnum 10 single w/ the splash/slinger oil system. The manual calls for straight 30w, however, I’d like to run synthetic to help keep the motor cool but because this is a flat tappet motor, I think I need an oil with high zinc. I was thinking of Rotella T6 5w-40 but didn’t know if the 40w would be a bit to thick to splash around and get into the tighter spots, plus couldn’t find out the zddp levels in the new formula. The other option is M1 10w-30 HM or a robust HDEO dino like Delo.
The motor runs great and has 600 hours on it with and no smoke. I just want this engine to last another 6-800 hours with regular maintenance and not have to use some rare oil that is impossible to find. Any thoughts?
Thank you for your help.
