Synthetic Oil ??
Toronto
Stupid question # 2. I'm presently using Castrol 20 W 50 GTX " Dino " oil. If I switch to 20 W 50 Amsoil,will I get better lubrication,Lower wear,and Lower oil pressure ?? Would lower oil pressure really matter,if you're using good synthetic ? Thanks.
ON, Canada eh?
In my opinion yes you would... Pressure does not equal better lubrication, it's flow that does and generally lower pressure equates to better flow in most circumstances because there is less restriction. They are both really great oils, but you being in the Winter belt like me, you are better off with Amsoil IMO.
Canton, GA
 Originally Posted By: StevieC
I use 10w30 in my Austin Mini, why do British cars need thicker oil? It doesn't burn or leak any. (Yet!)
"STEVIE-C" their tolerances are not as tight.Thats one reason,and probably more.
ON, Canada eh?
I know why you said it... I was bugging you. I do use 10w30 for now. When I notice smoke or consumption/leak issues I will thicken it up. I'm just happy the British stuck to cars and not rockets or Nuclear missles or we might have seen quite a different world!
Western Washington
No, you won't get better lubrication. Synthetic oil does not lubricate better than dino oil. No, you won't get lower wear. Oil pressure should not change. The main advantages of syn over dino are better cold starting characteristics, less sludging on prone engines and longer OCIs.
Washington St.
Not so at all. Better lubrication is the result of ample quantities of better oil at the right temperature in the right places at the right time. Flow just (a) gets the oil into places the oil flows out of, and (b) carries away heat and debris. Lower pressure does not at all equate to better flow if that lower pressure is from either lower pump output, a restriction along the way, or more leakage from the bearing. Have you been reading the ramblings of that cosmetic plastic surgeon, Dr. Haas? See Dr. Haas for a nose job. Consult with a tribologist or certain engineers for lubrication information.
Calgary Canada
Synthetic oil is not a better lubricant than dino oil except in these circumstances (generally speaking): - overheating; - long OCI's; - very cold temperatures. Check the UOA section if you don't believe me.
Duvall WA - Pacific NW USA
Well actually you can't use UOA's to judge "wear", and if you do - you will see metal amounts in PPM over miles is less with synthetic when you get beyond 3-4-5K, under 3K about the same. You also forgot that synthetic oil excels in turbo applications and in cases where a higher viscosity is wanted at operating temps without sacrificing low temperature flow.
Little Rock, AR
Sierra, that was actually your third stupid question. But who's keeping count. :) But seriously, I think it would be so cool to drop Amsoil 20w50 into the proper app. That's gotta be some Battleship Cruiser Class oil !
Kuwait
According to a Technical Advisor I've spoken to from a European lubricant firm, the general assumption is the oil's used in higher revving engines for longer periods of time, over a series of short trips. Also, they're more concerned with ACEA as opposed to the API.
Little Rock, AR
Then those Castrol 20w50 ads that ran thru the '80s and early '90s were correct - "20w50 for a high reving engine". It worked on me. I think I ran that stuff in my Subaru, my Datsun B210 (which I burned up the engine on*), my '85 Mazda GLC (sport) and my '88 Mazda 323. (* had an overheating problem. Mechanic "fixed" it. Next day I'm doing my 40 mile commute to work (listening to music, not paying attention). Feel like I hit a headwind gust, see smoke all in the rearview mirror. Sold it a few days later for $75 to the Salvage yard.)
Calgary Canada
Fair enough. I knew there would be add-ons, that's why I used the word "generally". The point I was trying to make is that dino oils are really good these days, and in my own opinion synthetics are needed only for unusual conditions like the ones described here. The turbo application in my mind relates to an overheating (at the turbo) condition. And I'll grant you that you can't get a 0w-40 in a dino oil.
