The minimum wet boiling point determines whether a brake fluid is DOT 3 or DOT 4. For example:
DOT 3 = 284F
DOT 4 = 311F.
Synthetics can be DOT 3, DOT 4, or DOT 5.1 while all silicon brake fluid is DOT 5.
Thanx but it just threw me when it said synthetic. I used to use silicon brake fluid in an older brake system but read to not use it in the newer ABS systems. It worked great on the race track.
I love silicone fluid in my older cars. I've heard it's too viscous for ABS. Don't know if that's true, but I dont care to be the guinea pig!
Mine was an 80 Camaro that was basically a race car on the street. The ABS system moves brake fluid at a rate the silicon can't match plus the orifices that it has to pass thru it's to viscous IIRC from reading.
I got some of that stuff myself today, in a yellow 32 oz bottle. I wanted to use DOT 4 this time round, but I posted about this earlier and it was recommended I use whatever is cheapest.
