MolaKule
Staff member
Quote:
I know a lot of people who run type f atf in these transmissions with great success and that's even older fluid then dexron3.
I have considered trying type f for the firmer shifts type f would bring but I have been warned that type f lacks the lubricating properties to keep the overdrive unit lubricated. I have found 3 different synthetic type f fluids that I am considering trying after the planetery upgrade. Amsoil super shift is one and redline racing atf and royal purple makes a racing atf that's basically a synthetic type f too and I believe ati makes a super shift synthetic type f fluid.
Being synthetic that should be able to lube my overdrive unit and having low friction modifiers like regular type f would make it shift similar to the original type f fluid.
Unless you race the vehicle there is no reason to use Type F.
Type F has the same AW chemistry as the other fluids.
What it does lack are the friction modifiers that provide the proper dynamic friction coefficients used in the other types of ATFs.
