quote:
Originally posted by Bill:
James,
A synthetic basestock would flow the same as a dino basestock if both lubes had the same cSt at 100°F,
some of the differences would be that a dino lube basestock may require more VII (Viscosity Index Improver) then a synthetic basestock if specific requirements needed to be met, and Pour Point Depressant would be added to the dino lube additive package to help the dino lube flow better at lower temperatures, some synthetic lubes have these additives but may require less or none of these the additives, having more additives can allow for more things to go wrong with the lubricant, VII is sheared, Pour Point Depressant is used up (degredation of the additive), the additives may not work as well as a new additive, synthetic lube having less or none of these additives allows for less to go wrong with the lube.
