As pointed out, the one advantage with 3/3 is that the oil gets “checked”/changed regularly, so even if the vehicle is burning/using 1 liter every 3K miles or so, it’s not really a big deal.
A friend of mine Michele (girl) just bought a new Ford Focus last year. When I asked her about checking the oil, she said it gets checked when she brings it to the dealer for its service and oil change (whatever interval that happens to be-- probably 6 months or a year. I’ll have to ask). She would never know how to check the oil and I imagine this is the case with the vast majority of females. I know there are even a fair amount of guys these days that never check the oil. Probably more than when I was growing up in the 70’s where just about every guy I knew had changed the oil in some vehicle at some point. Before the era of fast lube joints.
If these non-oil-checkers (which seem more common now than ever because more females are owning and driving their own cars) happens to be driving a car that uses a some oil -- say 1 liter/3k miles, and the oil only gets checked and changed every 6 months or once a year, and maybe up to 10k miles gets driven between an oil change. There isn’t going to be much oil left in that engine when it goes in for service, and a lot of that engines life will be spent running while low on oil and maybe getting down to as low as 1 liter at some points.
I think you could run the latest SM oils out to 5-6k miles without a problem. But for any “extended” OCI the oil needs to be checked and topped up if necessary. So something would have to be put in place for that.
