exposition:
Previous UOA
this fill is the LTS 3W-30. usual usage for this car, auto-x, romps, etc, but more commuting than normal. K&N oil filter, paper air filter, etc.
and so forth... basically, i think something's wrong. it runs well, but the series of events in its early life seem to have hurt more than was fixable via a rod bearing swap. the iron seems way high, and the only place i can think of that might be throwing off copper is the main thrust bearing. the lead seems too high even for new bearings, too.
i don't have time to pull the engine now and have my builder go through it, so i'll keep using/racing it until i do have time.
i put the last 7qts i had of schaeffer's #700 in it after this drain.
any comments/inputs appreciated, thanks.
-michael
Previous UOA
blackstone's comments: "we found copper to be high in this sample... we don't know if this could be related to the new rod bearings, or possibly from an additive you may be using. Lead was a little above average, likely due to wear-in from the new bearings..."code:
Al 3
Cr 1
Fe 33
Cu 55
Pb 27
Sn 1
Mo 76
Mn 1
K 1
B 84
Si 85
Na 1
Ca 3196
Mg 7
P 1141
Zn 1296
SUS 100C 67.5
flash 405
fuel
insolubles 0.3%
TBN 6.2
-michael
