My sister ownes an '01 Jetta with the 2.0L 4 cylinder gas engine, non turbo. It has somewhere around 70k miles on it.
I never paid much attention to what maintence was done on it in the past because its not my car. However after joining this site & reading up, it got me thinking...
The owners manual calls for a 5w-40 or 5w-30 oil that is A3 & VW 502 00 approved. It calls for 10k oci.
As far as i know the oil was changed aprox every 5-7k miles. Always done at jiffy lube other places of the like using whatever conventional oil they dump in it. The problem is that for as long as i can remember the engine has always gone through a lot of oil. Usually 1-2 qts have to be added between changes.
Id like to try switching it to a vw 502 00 approved oil to see if that helps the problem. The ones i see that are available at some local stores are M1 0w-40, Valvoline syn 5w-40, castrol syntec 0w-30 or 5w-40, or maxlife syn 5w-30.
Would i have any problem switching to one of these on the next oil change? I've read about people having problem with leaks or oil comsumption sometimes after switching to a syn on i higher mileage engine (although i've never experience this myself with my own cars). Would it maybe help to use a few qts of one of the above oils & a few qts of conventional oil for the first time? Then if that goes smooth switch to full syn the next time?
