I read somewhere that you can switch back to conventional oil after using synthetic for a long time without fear of leaks. Any truth to this? I am sure this has been answered before but I can seem to find a thread to answer this. The car I would like to switch back to regular oil is a 2002 Nissan Altima V6 with 150K miles on it all put on by me. I have had M1 Syn in it the whole time but I am starting to get leaks all over. (Rear main, rocker arm covers and a rubber oil line). I would like to just switch to M1 Reg but will this cause the engine to leak from everywhere?
The thing that caught my eye was the oil line where the leak was. The rubber was very gummy and soft on the outside. The rubber rocker arm gaskets however were brittle and harden. Is it common for gaskets to be effected this way by oil?
The rocker arms gaskets I replaced and I replaced the spring clamp on the oil line with a hose clamp so that solved those two leaks. I am not about to let a mechanic drop the transmission to replace the rear main if the seal is salvageable. Right now I am running M1 Syn HM to see if it will condition the seal and slow down the leak but will switching back to regular M1 slow the leak further?
