about 5 months ago i decided to start driving my sidekick again.it had been sitting about a year,the oil in it was kendall Semi Synthetic 10w30 w/marvel mystery oil stabilizer(less than 3k miles).i noticed i was getting a bit of engine noise the first few minutes of running and bit of rattle when the engine was lugged down.
last month i decided to change the oil filter and top off the crankcase.upon removing the oil filter i found the oil in it was almost a gel type consistency.no wonder i was getting engine noise.i added a pint of marvel mystery oil and drove for a few hundred miles.
i then did another filter change and drained the crankcase and filled with a mix of Valvoline MaxLife 10w30 and 5w30 Semi Synthetic and synth.now most of the engine noise is gone,seems to rev easier and i think the mpg avg has went up a little looks like 21-22mpg from 20-21mpg .only went through 2 tanks so far so it is hard to tell for sure.
p.s. what would cause the gelling of the first oil mix?moisture absorption?
