Originally Posted By: BuickGN
Originally Posted By: AdRock
Personally I find it much easier to control oversteer than understeer. If you want some brakes that will not fade hardly at all throw some cryo treated rotors and some of the Hawk racing pads on when you switch to the wilwood setup.
As far as the tires go, I've got some friends that do road track days & autocross and they've been happy with the new Nitto NT01 that came out recently.
If you want something for daily driving I've talked to people that seem to like the NT05 street tire. I've been thinking about trying some of those out myself.
I looked at those Nittos and I'm so glad I did. Even the street version looks very aggressive and it looks like it would be fairly quiet too. I'm not one to consider looks at all when buying tires but those things are pretty. On top of that, they're cheap.
Besides the obvious wear, is there any problem with running the race tires as a daily tire such as heat buildup on freeway trips?
The car is handling awesome. I went one step firmer on the rear bar and there's a hint of understeer at the limit but it's not bad at all. I'm very impressed with the difference in handling with a minimal change in comfort. Now I'm trying to wear these BFGs out so I don't feel guilty for buying the Nittos with half the tread left on my old tires.
I wouldn't put the competition Nitto's on a daily driver. In the heat and dry they would be great on the road. However, for rain they can be a REAL handful and cause you to almost shat your pants if you're not careful. Also, on the competitions the treadwear isn't great. Driving them everyday would wear them out quick.
So, since you daily drive the car go with the street Nittos. They still have a 200 treadwear rating so they're on the soft end of a street tire. They'll last longer than the competitions but will be better for year round street use.
One other thing. Go take a look at the Nitto's and compare the width to the width of the BFG's you have now. I'n the Mustang world I'm in a lot of guys, including myself, are running 315035-17's on the back. Nittos run narrower than most other tires of the same size. Nobody seeems to know why, but they do. A BFG KDW 285/40/17 is just as wide as a Nitto 315/35/17. So if you do buy the Nitto's you might think about going up a notch or two in tire width to get the same contact patch you have with the BFG's now.
