Hi again all! As in post title, which would have the most,additive? I used to !if tcw3 with gas, at 1 oz.per 5 gallons. 98 corolla.sometimes I gained mileafe,often not. I used supertech. I wanna play around again,but now,with a 98 lesabre. I know,the hypertext smells sulphur. It's mineral based? The gasoline and pennzoil,are synth mix. And quicksilver is it? Walmart..has a synthetic.
I've seen one point here,his piston tops were spotless! Using tcw3. .
Are they all the same,literaly? Or does one brand have more detergents?than the other? The brand's I'm interested in..supertech,valvoline,pennzoil. Personaly,im a valvoline guy. Supertech andvalvoline,I'm mostly leaning on. 1 oz.per 5 gallons.
I do use Lucas ucl.read it's non detergent. It allegedly,it isnt. Without. Lucas,or MMO,I will get about 179 miles. With, and using citgo gas,87...200-205 miles.but with Mobil 87,and lucas/MMO..I've gotten 260 miles. Synergy? I will never get over 200 with citgo.
SO! Wanna play around again,with a high detergent tcw3,..from thread title!
