N N1887T Joined Aug 26, 2020 Messages 4 Oct 21, 2020 #1 Bought a bunch of this when it was discontinued. Looks pretty good for mowers and older engines. Rated API SG too. Attachments SUPERTECH 30W-201017.pdf 63.9 KB · Views: 522
C Chris142 Joined Jun 5, 2003 Messages 28,017 Location Apple Valley, California Oct 21, 2020 #2 Don't need much detergent when you are always adding oil to you're Green leaker Detroit.
B bullwinkle Joined Oct 9, 2004 Messages 14,567 Location Cincinnati, OH, USA Oct 25, 2020 #3 ZDDP levels are actually reasonable, I wouldn't hesitate to use that in an IDI 4 stroke diesel (like the 7.3 in my sig), even though it technically isn't approved for CH-4 (or higher) for short OCIs (or quick leakers).
4WD $50 site donor 2024 Joined Sep 21, 2010 Messages 25,303 Location Texas via IAH Oct 25, 2020 #4 I bought a few bottles of ST HD30 for $3.12 each and its gone now. Surprised to see it was SN Plus.
Creekside Joined Jun 12, 2020 Messages 1,451 Location SW Missouri Oct 27, 2020 #5 Chris142 said: Don't need much detergent when you are always adding oil to you're Green leaker Detroit. Click to expand... The less detergent the better, some sludge might actually slow some leaks down
W wpod Joined Jul 12, 2012 Messages 9,281 May 21, 2021 #6 Chris142 said: Don't need much detergent when you are always adding oil to you're Green leaker Detroit. Click to expand... I hated everything about those engines .
53' Stude Joined Mar 12, 2015 Messages 28,507 Location In the shop May 21, 2021 #7 4WD said: I bought a few bottles of ST HD30 for $3.12 each and its gone now. Surprised to see it was SN Plus. Click to expand... All the CQ SAE 30, 40 is SN+
53' Stude Joined Mar 12, 2015 Messages 28,507 Location In the shop May 23, 2021 #8 4WD said: I bought a few bottles of ST HD30 for $3.12 each and its gone now. Surprised to see it was SN Plus. Click to expand... This CQ SAE 30 is SP. can’t figure out the date code. Attachments image.jpg 237.9 KB · Views: 36 image.jpg 262.6 KB · Views: 35
Brons2 Joined Sep 16, 2003 Messages 4,793 Location Austin, TX MSA Jun 17, 2021 #9 Chris142 said: Don't need much detergent when you are always adding oil to you're Green leaker Detroit. Click to expand... I would only use 30wt in a DD 2 stroke in a cooler climate. Most people recommend and use 40wt.
