SunJoe pressure washer and Amazon foam cannon...W8 all clean!
TiGeo
$50 site donor 2024
VA
Chemical Guys Mr. Pink soap and my Amazon "SunJoe" pressure washer and cheap Amazon foam cannon. Maguiers All Wheel cleaner. Got the W8 looking good for a quick rinse off and dry..no scrubbing needed this time.
Have the same setup but used Meguiars Gold Class Shampoo, my SunJoe is almost three yrs old and is starting to act up, cycles when not using the gun. :unsure:
Mine does that too...I believe that's normal.
usually that means you have a leak somewhere. either internal or external. most of the stuff inside these cheap washers are plastic and they develop cracks .
These do this since new, just something with how these work. It's just a quick cycle on/off...probably to maintain pressure is my guess.
Would someone please explain the rationale for using a pressure washer on a car? :rolleyes::unsure::confused:
These are not industrial pressure washers here. Works great to knock dirt off, clean wheels, etc. Foam cannon put a thick nice layer of soap down. Not sure why this is strange/requires explanation? This is about what every detailer uses....
