Patman,
I beleive it did contribute to the higher oxidation levels that you had.
Sulfur is a great lubricant that is used as such in a lot of cases. The problem is that when burned it turns into a sulfuric acid which carbonizes up and then creates hot spots as well as seeps past the rings, causing the oil's tbn to be reduced a little faster than if not there.
In diesel engines where sulfur is common in their fuel, this is true and why a TBN count is more desirable vs a car which gas has minimal amounts in most cases.
That is why in my fuel
test videos you'll see me using actual sufuric acids to see how a fuel additive will neutralize it as this will help the oil from having to become depleted as much.
As for the damage, I beleive that what happens most is carbon builds up in the cyl's, cause valve wear reccession, could cause sticking valves,in diesels glow plugs become heat sinked to the head therefore not able to produce the preheat for easy starting and such. It also introduces more acidity to the oil reducing oil's ability to extend drain intervals.
As for metal wear and such I'm not sure that the sulfur itself would cause a problem here because I know it has and still is being used in off road diesel fuels and this does provide lubrication for the seals. When Gore had reduced the sulfur in OTR diesel fuels, a lot of diesel engines began to have seal/pump failures due to the lack of lubrication that was provided by the fuel which now has been rectified by manufactures.
This is one primary reason I strongly use our neutra 131 to eliminate any possible problems due to this. I can take the neutra and drop sulfuric acid directly in it and it instantly neutralizes the sulfuric acid. This is another reason for using this when changing over oils where the previous oil may not have been able to maintain acid neutralization, the 131 will provide this and then the new oil won't come back deplete prematurely having to work overtime cleaning up from the previous oils lack of ability to keep acids in check.
I suspect I just opened up a new bucket of worms here but hopefully helps explain more on the cause and effects of sulfur.
[ July 31, 2002, 10:10 AM: Message edited by: BOBISTHEOILGUY ]
