suggestions for high mileage Toyota 2.2L
Vaughan
I am using Delvac 1300 super as well, but it had just been discontinued from Walmart. I am now trying to find time to get to my local NOCO to get some.
Again I am in agreement with Jelly. Delvac 1300 15W-40. If Walmart does not have it, try truckstop convenience stores. Or, an oil distributorship may be able to get it, even if it is not a Mobil dealer. Mine was not, and I got it from them.
quote:
Originally posted by Hajoca: I am using Delvac 1300 super as well, but it had just been discontinued from Walmart. I am now trying to find time to get to my local NOCO to get some.
Maybe in Canada, but not here in the U.S. Delvac has actually received MORE shelf-space here with the addition of quart bottles!
Going to do oil change for my dad's '92 Toyota Camry 4cylinder 2.2L. Its got about 153,000+ miles on it. Car has been running 10W-30 or 10W-40 conventional oil. It still runs good. Should I use a 10W-30 high mileage oil? Or would 15W-40 be a better choice, not sure if 15W-40 is okay for this car.
One school of thought says that cars are expensive and oil is cheap, so change it a lot. Another says, new oils are so much better than in the past this is not necessary. Since I started driving when oil was less than optimal (people put a quart of transmission fluid in with parrafinic base stock oils to hold down the sludge) I do the 3,000 miles routine so I can sleep at night. These days, the companies that do UOA will look at your oil and tell you whether you need to change more often. So, a few bucks well spent might be the ticket.
quote:
Originally posted by lpcmidst128: not sure if 15W-40 is okay for this car.
Yes, it's perfectly fine. I'd recommend Mobil Delvac 1300.
