i read all the posts, there doesn't seem to be a consensus. i'm considering torco rtf in my new impreza, has anyone used it successfully in an application that calls for a GL-5?
it would be good to know if the subaru tranny truly requires a GL-5, or if a GL-4 would work. what would the difference be between the diff in the subaru versus a vw, for instance? is it because of the center diff? (i'm assuming the center diff is lubed with the tranny and front diff.)
neo has a 75w90HD which they specifically state is for GL-4 tranny use, and sexy to synchros, but also meeting GL-5 specs. however, reports on the subaru forum have been both good and bad.
lastly, what is it about petroleum vs synth that has synth GL-5 lubes causing bad synchro action, but petroleum lubes working fine?
thanks.
-michael
thanks.
-michael
