Looking at possibly buying an early 90s Subaru for my son to drive. It would have to be an AWD version. I have no personal experience with Subarus. Is there any models or engines to aviod or try to find? Can these cars do a 200k miles with proper maintance or do they enventually become a money pit? Thanks.
I can share my experiences with 1992 Loyale, which is I think what you want.
Problem areas:
3-speed transmission went out at about 140K miles. Transmission problems are rather common even on bigger and nicer Legacies.
At 180K miles:
Wore out the engine by 180K miles. One cylinder was not working, running on 3 only.
Tends to burn/leak oil.
Had to replace timing belts because the tensioner went bad.
Computer went bad, stranding in the middle of nowhere.
All in all, they are great deal with something like 100k on them. The engine has aluminum heads which are prone to cracking if overheated. Doesn't really impact anything but lowers compression.
I had both the transmission and the 1.8L engine replaced and the newer bone yard engine with 95K still burns or leaks oil. But gets really good MPG at 29, and has decent power.
The resale value is very low. Should be able to find one for $500 and drive it until it falls apart, probably for at least 50K miles. Some report excessive mileage such as 200K , or 250K but IMO with that kind of miles, lots of things will have to be replaced. Like entire axles, and more.
They are also prone to rust.
I hear that Legacy is a much nicer car, twice the car than Loyale. Loyale is in all honesty cheaply built. No cruise control, windows don't have frames like more expensive cars. But I like Loyale. It is compact, simplistic, cheap and you don't care if you wreck it. Neat thing about Subarus, they come with tach by default. And they handle great in snow.
