Link
Quote
Ok guys, I finally got off my butt and disassembled the old engine. I was actually very surprised at the results. If you've been following along, you know that I've been using Mobile1 extended performance 0W-20 along with Fram synthetic oil filters at 12,000 mile intervals for the full 600,000 miles. Ignoring the oil leaks, this engine looks great. The cylinder walls show no wear and don't even have a wear ridge at the top of the cylinder. The piston tops have a bit of carbon build up but nothing unusual. In the last days I was using a significant amount of oil and I can only contribute that to excessive wear on the oil rings. All of the bearings look great and the camshafts show very little scoring. Compression was fairly consistent with all cylinders with the exception of cylinder #3. After disassembly of the heads I found the the valves on #3 had more wear than the others and we're definitely burned resulting in cylinder #3 occassionally misfiring.
My take on this is that if it weren't for the burned valves on #3 cylinder and the oil rings wearing out, this engine would have easily reached a million miles. So maybe if someone at Subaru is listening, you might take a very hard look at what oil rings you are using. As for me, I'm sticking with 12,000 mile oil changes using Mobile1 extended performance and Fram synthetic oil filters. Hopefully I can get another 600,000 miles on this next engine.
Quote
Valve and piston carbon build up was actually far less than I actually expected. Apart from the burn't valve and normal Subi oil leaks, this engine doesn't look like it has more than 100k on it. This was even cleaner than I expected.
Engines like to be run. Run them often and they will last. The guy is a medical courier and drives 800 miles a day. That's insane.
Quote
Quote
