JeffKeryk
Do you have any information on this? A website would be great. Thanks.You have to put the computer onto brake maintenance mode before you replace the pads.
Just a guess but I'm assuming it's to retract the rear parking brakes? Not sure why you would have to for front brakes but I learn everyday.Do you have any information on this? A website would be great. Thanks.
At least for warranty work, any part in the workshop manual that says to discard and be replaced, must be billed out or the entire repair will be rejected.Does anyone actually do this?
Doesn't say that the technician actually replaced them though !At least for warranty work, any part in the workshop manual that says to discard and be replaced, must be billed out or the entire repair will be rejected.
Correct, only for the rear brakes where the parking brake is.Just a guess but I'm assuming it's to retract the rear parking brakes? Not sure why you would have to for front brakes but I learn everyday.
As long as my base is covered I am good. Plus we have to make sure that the parts are here and Ford shows a purchase history from us.Doesn't say that the technician actually replaced them though !
If you don't know, the inside and outside pads are different. Make sure you install them correctly or they won't contact the rotor correctly. Pay attention when you take the old pads off
No need for brake service mode if only doing the fronts. The parking brake on most 2.7 F150's is electric.
Ford changed the spark plug number, I put in the replacement number at around 60,000 miles. Pretty simple. Only the right rear plug had interference that made it less fun... And frankly, the plugs were in excellent condition and could have easily made 100k. Old habits from breaking 3V plugs made me get in there early...
Humps to the inside. I THINK Ford revised the different inner outer pads to be interchangeable. I will find out soon as I am using all Motorcraft parts.not sure if it applies to the 2015+ trucks, but:
Tech Tip: Ford F150 Inner and Outer Brake Pad Mix Up - Safe Braking
On the 2010 to current Ford F150, the inner and outer pads are different. If the pads are mixed up, the caliper can hit the spokes on the wheel and cause damage. The inner pads’ backing plate has two ears on the top of the pad that match up the the brake caliper pistons. The [...]Read More...www.safebraking.com
Agreed. My take is, I do not know the history of this vehicle. I will not cut corners. New fasteners will be used. My Bonney torque wrench will make the 184 pound feet a snap!Ford MAY have, but the aftermarket is full of the pads with the ears on them, and the F150 boards for the 2015+ trucks still see posts from folks asking what they did wrong when the pads aren't contacting the rotors correctly...
Also will note that the Ford Manuals state that a lot of fasteners are one time use only. This is not new on the 15+ F150's and dates back to well before then. As one might imagine, there are a ton of these units that have work done on them, and don't have the fasteners replaced every time.... Not saying it is right or wrong, but...
Some makes and models yes. How often are you doing it that it’s a problem ?Wow you actually have to replace the caliper bolts every time?
Without knowing the size and design of the slide pin, it's hard to automatically say that's high. On our son's '12 Accord, the spec is 26 ft/lbs whereas on my G35, it's only 18-20 ft/lbs.27 ft-lbs. for caliper bolts seems high.
DOUBLE CHECK THESE. TRIPLE CHECK. I fell into the Google trap and got bad info.
27 pound feet is from the Ford Service Manual.27 ft-lbs. for caliper bolts seems high.
When I tried torqueing my caliper bolts they "creaked" and went soft at 25ft-lns. Thankfully I could back the bolt out before it broke all the way.
My advice is to have a spare set of caliper bolts, use Loctite and only tighten these to wrenched-snug plus 1/4-1/2 turn.
27 ft-lbs. really isn't that much torque. You can easily hit that with a 1/4" ratchet.27 ft-lbs. for caliper bolts seems high.
I have at least 4 torque wrenches. I inherited 2 special ones from my older brother who had a great shop in Santa Cruz, CA. One is a 3/8" Snap On flex head and the other is a large Bonney that goes to 250 pound feet (or more, I forget).27 ft-lbs. really isn't that much torque. You can easily hit that with a 1/4" ratchet.
That's the torque value listed in the Ford service manual on my desk. Not saying I always use exact torque, but that's in the ballpark of how I'd tighten by hand anyways.
