stuck caliper pin
Near the beach in Delaware
When replacing pads, rotors and calipers on my Camry I noticed one side had one of the caliper pins stuck, and on that side the inner pad was gone and the outer pad hardly worn. I had to put it together with the pin stuck as I needed to use the car, but what do I need to go back and replace.
You'll wear out the inner pad again (in short order) until you fix the problem. Once you manage to get the pin "unstuck" you should clean off the corrosion to the extent possible. I generally use the wire brush on my bench grinder for that or a dremel+brush when the pin is inconvenient to remove. Once you've got it cleaned up, lube it up with a quality high temp brake grease. If you haven't already, I'd also take the opportunity to do the same thing to the other side as well.
You will likely have to heat it up to get it out. Take off the rubber boot, and apply heat to the casting. Propane heat may not be hot enough, and you may need acetyene
It's been a long while since I've done the brakes on a camry. Got any pics? A generous dousing with PB Blaster and some twisting with the BFC (big channel locks) usually works for me to free it up. If it has a rubber grommet that you can remove, you can also try a little heat. I've got one of those cheapo MAPP gas + oxygen torch setups from Home Depot that usually does the trick when I need to heat things up.
Pressed in. I've put the pin in a vice and spun the caliper around to loosen it and hit the side of the caliper out with a hammer while in a vice.
I would just replace the front calipers with a set of remanufactured semi-loaded calipers.
Considering that your Camry has nearly 200k on it, the calipers are probably tired.
If the pin can be twisted, then there is no need for a new caliper as the pin can be removed. Even if the pin is severly pitted from corrosion, just replaceing the pin is enough.
I had a similar situation in in-laws Jetta about 3-4 years ago, I cleaned everything up, gave plenty of lube and re-assembled. This year the rear pads needed changing again and all the pins except one (on the drivers side) were moving smoothly. The one that was stuck had a torn rubber dust boot, all others were fine.
To help in pin removal try twisting and pulling on the caliper at the sme time, it will slowly come out.
Considering the age of Donald's car, his calipers may very well fail tomorrow and ruin his new set of pads.
If he plans to keep his car for a while, then installing a set of remanufactured semi-loaded calipers would be a wise decision.
I didn't realize that stuck pin = ruined caliper especially if the aftermention caliper works properly after clean up and has all dust boots in good contition.
I would be more concerned about brake lines at this piont, since they may be rusty and rubber may be swelled/cracked.
The car has new calipers (but just the basic caliper) along with pads, and rotors, so I am not going to install semi loaded calipers.
new calipers w/ stuck pin? that's really sad. the brackets for my car are just the bracket, but you should ask them. if you can't get it out, you have to take the calipers back
and yes, i would regrease the pins even when new like mechtech said. i like the ceramic green grease it lasts longer
Originally Posted By: [RT
ProjUltraZ]new calipers w/ stuck pin? that's really sad. the brackets for my car are just the bracket, but you should ask them. if you can't get it out, you have to take the calipers back
I bought a basic caliper, which fits into the bracket. So the bracket and pins were old, only basic caliper was new. The caliper bolts to the bracket which bolts to the wheel.
