You're welcome, mjo. Glad to be of help.
When you heat the epoxy it will initially soften and become pliable long before it burns up. I speak from experience of using a torch to remove electronic components from scrapped epoxy circuit boards. Heat will make the epoxy sag like a limp . . . whatever.
T.P.F.T ("turns past finger tight") specs are interesting because normally one would find a torque spec for threaded fasteners. But in the case of pipe threads you have the additional variable of a thread sealant which could have a wide range of coefficient of friction, depending on the sealant. So it is more reliable to use T.P.F.T than torque when dealing with pipe fittings. If you are interested in more information, Maryland Metrics has
this assembly guide (pdf) which you can download, if you think that you might find it useful. They refer to the spec as "Turns From Finger Tight" T.F.F.T. The pdf includes tables with values for different types and sizes of fittings.
When it comes to a high performance thread sealant for automotive applications, I highly recommend "Permatex High Temperature Thread Sealant" (part number 59214). This is NOT an "instant put in immediate service" type sealant like Permatex #14. On the contrary, "Permatex High Temperature Thread Sealant" requires several hours of curing time before putting the joint into service, and will actually continue to cure for 72 hours. It provides a solid, heat resistant, vibration proof seal, but it can easily be disassembled when need be.
Permatex lists the following attributes for "High Temperature Thread Sealant":
- Prevents leakage from vibration, temperature cycling, and extreme pressures.
- Protects against rust, corrosion, and galling of threads.
- Parts repositionable after application.
I have done a lot of automotive plumbing with NPT and BSPT pipe fittings -- custom oil coolers, custom oil pressure alarms and pressure sending units, tranny coolers, and radiators. As you may guess, I highly recommend Permatex HTTS for demanding applications.
Many years ago, there was one main choice for automotive threads sealants, good old Permatex #2. You might remember it as that black goo which required alcohol to clean up. We sure do have a lot more choices now, with better chemistry. Permatex "High Temperature Thread Sealant" gets my vote as the current "top dog".
[and no, I'm not associated in any way with Permatex]
