Ok I know everyone says to NOT go by the oil's condition via the color of the oil.
Here's the situation:
1981 Ford T-bird, 302 V8, with 2-bbl 2150 carb (no sensors, not the VV) with the AOD.
Stock filter size is Motorcraft FL-1A, or SuperTech ST8A.
I installed thicker Hellwig anti-roll bars on the front and rear, but the front bar is so thick that I had to use the smaller FL-300 or ST16 designed for the late 80s/early 90s (pre 4.6) Crown Vics with the 5.8L V8 police option w/ the oil cooler (the story is that the oil filter adapter for the oil cooler lines was too thick, so they had to use a shorter oil filter - the FL-300).
Ok fast forward to my situation:
I use Pennzoil, or Quaker State dino 10W-40 in the 302 V8 frequently. Change interval is usually 3 months or 1000 miles whichever comes first.
With the FL-300/ST16, I'd notice that the oil turns black (considerably darker than when its new) at about 500 miles or 1.5-2 months. During this time, the car is harder to start and my gas mileage drops considerably!!!
I just changed to Chevron Supreme 10W-40 and squeezed in a FL-1A but only tightened it gingerly. I'm HOPING it will come off at the next change w/o tools (the bar leaves about 1/16" clearance between the filter and the bar, eliminating any chance of squeezing in a wrench.
Anyhow, the engine starts up really fast on cold starts - it just springs to life. gas mileage is also up considerably. After a few local errands my gas needle didn't move even when doing a few burnouts and high RPM runs. Usually the needle would have dropped about 2mm.
The oil is also "crystal" clear.
On the Ford 5.4L SOHC V8 and 4.6L SOHC V8 engines, the oil is still crystal clear on the dipstick after 3 months/1000 miles.
Can I assume that when my T-bird's oil gets darker, that its time to change the oil? Considering there MAY be a loss in oil pressure due to a clogged filter?? Or how else can you explain this? The 302 as with all of my engines, have been taken care of since day one. Frequent oil and filter changes, etc...
