The same engine in an industrial application, generator, etc., will probably have a straight 40 wt. oil and heat on the engine when it's shut down. You don't want to start a cold engine with 40 wt...if indeed it'll crank fast enough to start. The straigh 40 is cheaper.quote:
Originally posted by widman:
A lot of theories to try to explain it, so here is another question. Truck makers do not have to comply with mileage standards. They sell the big things based on how many million miles they can run with the big guys on long haul and delivery routes.
Volvo won't recomend any thing but 15w40, Scania, Mack, Caterpillar, and Cummins the same. Why?
I've seen the videos of the Volvo VDS 2 examination. 320,000 miles of heavy work with 40,000 mile drain intervals. Take the engine apart and can't have that ridge on the sleeves, nor other signs of wear.
If there is any truth to lower wear with single grades, why don't they use them?
Ken
