Noxudol 700 is a thin, penetrating rust protective compound intended for treatment of the hollow spaces of motor vehicles according to the ML method. In addition it may also be used as transport and storage protection for machines, machine parts, beams, motor parts etc.
grease em up, them saran wrap emHi guys,
I want to store a set of camshafts.
As they are prone to rusting, is there a special oil spray I should be using to ensure they don't rust?
Yes, this. Cosmoline in particular is a real pain to remove, and the temptation will be to rush things, which will cause scratches. Use Cosmoline only if you're intending to store those engine parts for your unborn grandkids to use one day.Motor oil and bag. Anything else just creates the possibility of scratching a crank journal when removing a coating.
LOL I don't think even the most hard core enthusiast is going to store automotive cams under their bed. 🤪A guy I used to work with showed me some collectible Browning shotguns and rifles he owned . He wiped them down with Vaseline and shoved them in a zipper gun case and put them under the bed . They had been stored that way for years and were pristine .
Actually it was about using the Vaseline as a cheap but effective metal protector .LOL I don't think even the most hard core enthusiast is going to store automotive cams under their bed. 🤪
My response was more joking...Actually it was about using the Vaseline as a cheap but effective metal protector .
This would be ok except DO NOT USE PLASTIC. Waxed paper or at least newspaperDo like they package brake rotors...light coat of machine oil and wrapped in sealed plastic.
