Well, I'm still having ignition issues with my '87 Buick Century 3.8L.
To recap, the motor was running rough and smell of unburnt gasoline was evident at the exhaust pipe. Through a bit of trial and error I found that when either or both of two of the plug wires were removed, the motor didn't run any differently. Those two wires are both fed by the same coil on the ignition coil pack. Thinking that I probably had a bad coil I removed the pack (contains 3 coils, each coil serving two cylinders). Testing with a multimeter revealed that the primaries and secondaries all tested within spec. Since the suspect coil was one of the end positions, I found that the coil can be installed rotated 180 degrees. Doing so, the same two cylinders were not getting spark - meaning the problem didn't follow the coil. As an educated guess I bought a new ignition module (this car has had ICM/coil issues multiple times over it's life) and installed it today. Problem is the same.
Now I'm stumped. I'm curious if anyone knows if the ECM sends signals to the ICM for each cylinder or pair? Or more broadly, what else might cause this condition.
One bit of info: the car was being driven and running smoothly when I had to make an abrupt stop on a bumpy railroad crossing - when I accelerated away the engine was running like garbage (as one would expect with two missing cylinders). Also, this is the Motorola/type 1 ignition system. Any sensor or wire that could have busted?
I'm out of ideas and welcome any thoughts....
