Stihl Trimmer Issues
Madison, Wisconsin
So, I have a "new to me" FS 55 RC trimmer. Had it about 2 years. Been feeding it 91 ethanol free and stihl synthetic oil. It's always been a bit balky to start and needed to run with the choke on slightly to avoid stalling... I figured possible carb issues, but it never was a big enough issue to monkey with.
Two weeks ago, it wouldn't start. I took the carb screws back to their recommended starting position, did a lot of pulling and got it going again. somewhat. It's got the 3 screw adjustable carb. walbro (sp) maybe?
Now, it will run at idle but it starts stumbling when I hit the gas. I have to "work it" to high throttle by slowly pulsing the trigger back and fourth. Slowly, I can go a little faster with each pulse. I can finally ease it to high throttle, but it bucks and misses initially. It will miss for 5-10 seconds, then catch and take off.
Yesterday, it started something new. Once it was running at high throttle, every time I let off it just died. Flat out. No coughing, it just stopped like I hit the on/off switch. It does this every time. I unscrewed the gas cap in case there was a vent issue. No change. It seems to be happy when locked on full throttle, and ran as long as I wanted it to.
My assumption is that I've got carb issues and need to rebuild or just replace. But with all the new issues, I wanted to get opinions. I'm by no means a 2 cycle expert.
Thanks in advance!
You nailed the diag, it seems a carb problem, running lean/fuel delivery problems.
My first step on those is to get the number off the carb and google it, check E-bay as well. I have bought 2 Walbros for trimmers ($18-21 each) vs $12+ shipping for an overhaul set. I am naturally lazy, so $8 extra for a complete carb is a simple choice. I did eventually get carb kits for both those carbs and rebuilt them (it gave me a chance to use my new ultrasonic cleaner), so I have 2 carbs ready to go whenever a problem arises.
I recently experienced the same symptoms with my 9 year old FS 85. I rebuilt the Zama carb which yielded little improvement. I was pleasantly surprised to find that the dealer price for a new carb was only 37 bucks. I bought a new one on eBay for even less and now my trimmer runs like new.
I've got a Deere trimmer, would be hard to start, and then run on a fast idle. All the time.
I was recommended Polaris Carbon Clean fuel additive, used it according to the bottle, and switched to a premium fuel. Fixed. Idle is back to normal, and its running great.
Don't know if it would work with yours, but for $8 I was willing to give it a try.
Check the exhaust before you get too involved - most Stihls should have a removable spark arrestor,remove it and clean the gauze.
I have a FS 85, and I was recently having problems with it dying when I gave it a lot of gas. It ended up needing a new fuel filter. The fuel filter is inside the tank at the end of the pick up hose.
Just another thought to check. Good Luck.
thanks for all the suggestions guys! ended up being the carb. I decided to just replace it, and it runs like new. I could have rebuilt it, but the price difference wasn't enough to make it worth the time.
