I have 2 Stihl BG86 blowers, (both are non catalyst) one for the FL aircraft hangar and one for my home. While they are about the most powerful hand held gas blowers around, they only make 1HP and are 27cc's. An engine that size should be near 1.5HP. I figured the muffler was probably the culprit. So I pulled the muffler, studied it, and cut a large opening in the middle baffle. I then machined the "tailpipe" nozzle to a larger internal diameter, and machined it for a smooth flow transition.
The result is really interesting. It's sound at idle is quite a bit sharper and louder. But when at full power, it's not noticeably louder than before. Throttle response is considerably better, and yes, it makes more power. I will compare the two blowers side by side when I get a chance, but it's clearly better with the muffler mod.
Interestingly enough, the force from the nozzle is, by feel, obviously faster and higher pressure than before and it shows in the arm-tiring thrust it makes.
