I recently completely flushed out the P/S system with Dextron. I had a very slight leak a drop out the rack boot after sitting over night. Apon checking the level, it being good the fluid was filthy black so I flush all with fresh Walmart dex II & III Mercon. I added Lucas P/S stopleak about 4oz. and is curently not leaving a drop on the ground at this time. Why should I replace this atf fluid on this 1996 Northstar engine. I have racked up 1000mi since. The P/S seems good but I don't need problems.
