That's a good idea.
I figured out which wire is the ignition lead and ran a new wire off of that, but I'll have to look into that for a more permanent solution. Does the fuse control the lead or the 12v signal, though? the 12v signal is fine, it's just the lead is goofy.
And yes, I did check the fuse before I did this. it is fine.
