JHZR2
Staff member
Hi,
I installed Zimmerman cross drilled rotors and textar pads on the front of my 91 318i many years ago, after I refinished a set of basket weave alloys for it. Knew less than I do now, but they have given great service and have stopped well. Pads are still over 50% 60k+ later.
Thing is, recently when stopping, the steering wheel starts moving in a range as I apply the brakes. Side to side I suppose, but not horizontal motion, rather it moves as if I was quickly steering right to left with about 1" of motion back and forth in the wheel. Seems worse when using the brakes a lot, and it seems that heavier pressure mitigates it somewhat.
Car drives, rolls, steers perfect, no odd tire wear.
Is it safe to assume that the brakes are to blame? They stop well.
I can get bendix ct-3 pads for $18 and bendix rotors for around $20 each for this car, so want to pull the trigger if it is likely the culprit. No other indication that it's the suspension. Could it be something else? Does it on both my snow and regular tires.
Thanks!
Thanks!
