After applying Militec-1 and CLP to a pair of iron nairs, I left them out in the rain and went to check on them about 12 hours later. Both had surface rust... so I decided to do this uniformly and grab about 6 nails of the same type and 6 different lubricants.
In about 12 hours I'll post a report on my findings.
The contestants are whatever I could find in my house:
* RemOil (Remington Oil)
* Outer's Gun Rust Preventative Lube (smells like SAE 20 machine lube you get in a squirt bottle)
* Break Free CLP
* Firepower-10
* Supertech Dexron III/Mercon ATF
* Mobil 1 15W-50
The reason I did not test Militec-1 was because I ran out of nails. Since it failed the initial corrosion test I wanted to give my two "hopefuls" a shot at the title (ATF and Mobil 1).
I'll post the testing methodology and everything probably tommorrow.
FYI - I made a modified version of Ed's Red to use with my VEPR K: Household Ammonia, 70% Isopropyl Alcohol, Kerosene, and Dex3/Merc ATF. The alcohol is miscible with polar and non-polar components, so I use it to make it as uniform as possible (solution rather than a pure mixture).
I also found Brasso to work very well in cleaning up the gas piston. Nothing else would take the carbon off as readily, and its designed for chrome, stainless steel, and other high luster metals so I figured it would be safe. Heck, I use it on Lexan headlamp lenses and it doesn't make so much as a scratch.
BTW do NOT use ammonia on aluminum - it will react!!! My Outer's rifle cleaning rod is aluminum and it started reacting with the ammonia. I could not see any violent reactions, more like an oxidation of the aluminum.
* Break Free CLP
* Firepower-10
* Mobil 1 15W-50
