Starbrite"Startron" additive?
Buffalo,NewYork
I was at walmart yesterday & saw this fuel additive on the shelves. Must be new as I never saw it there before & only 1 8oz bottle left."Startron Enzyme Fuel treatment for all Gasoline Engines" Here is the web address to the product:
www.starbrite.com
located in Ft. Lauderdale,Fl.
1-800-327-8583
* Reduces all emissions
* Prevents fuel oxidation and stabilizes fuel chemistry for at least 1 year
* Lowers fuel system maintenance
* Eliminates carbon build-up in fuel delivery system and on exhaust components
* Increases fuel economy, especially in older engines. Instantly cures fuel jelling caused by cold weather and E10---alcohol fuels.
Kinda poorly worded. I didnt know gasoline "jelling" was a huge problem
I saw this stuff at Walmart last week in the camping/boat motor section. It was kinda expensive to by my memory. Its odd that you found only 1 bottle, and so did I. Possibly they only purchased a handful to see if the stuff sells.
On a positive note, I noticed my walmart has lowered the price of Gumout Regane to 4.94 a bottle. It was 5.32.
This is sold for marine use; boats can sit up for months and "phase separation" is [said] to be a problem.
WEST MARINE has this and other fuel products by this company on its site.
Started using STARBRITE products after numerous trips to WEST MARINE this last summer. On my diesel engine truck I've been running (and continue) FUEL POWER FP-60 which I used to pick up from Odis or the guys at LCD.
Thought I'd try the Starbrite Tank Cleaner, figured it couldn't hurt (wouldn't be as nasty as using a biocide), and, after all, the previous owner had put 120,000 miles on the truck in about two years. I used that stuff a little stronger than the recommendation and kept a spare fuel filter on hand. Power started to slip once the filter had 5,000 miles on it, so I swapped it out.
http://www.powerandmotoryacht.com/maintenance/starbrite-star-tron-enzyme-fuel-treatment/
I've been using the Startron Enzyme Treatment since then (after Christmas) along with FP-60. My fuel mileage is consistently 19 mpg in town in this 7,500-lb truck.
http://www.startron.com/stretch.php?sec=2
Dosage for my truck is about one-oz per fill. The Texas Gulf Coast is very humid much of the year, so I hope to avoid any "fuel bugs" by a tank cleaning and continued use of additives.
