Okay so I guess the ocd is kicking back in but I recently replaced the drain plugs on two champion generators with stainless steel ones (304) and now I’m wondering if this will cause a corrosion issue? The blocks are aluminum and I know the two metals can cause galvanic corrosion in certain cases but is this one of them? I’d hate to have the threads or something corrode and leak. That or have the plug seize in place.
The generators had from the factory some rubber hose setup where you could lower it into a pan to drain the oil but it was extremely slow. I decided to just unscrew the hose assembly and that’s when I had to purchase some plugs to go in their place like a typical engine would have. I have a feeling this is fine but I wanted a second opinion.
