Before I start, I know this is a band-aid solution but GM hasn't given myself or others much of a choice when they don't make the bearing serviceable and my only option is to replace a $900 drive shaft assembly. This is on a 05 Cadillac CTS-V and bearing squeaking is a pretty common problem.
I'm looking for a lubricant that has penetrating abilities to get past the bearing shields, yet leave a good bit oil behind for lubrication and protection.
I've looked at MSDS sheets for WD40, TriFlow, WD40's Blueworks, etc. and found these are basically varying blends of naptha, kerosene, and some other solvent.
Surprisingly, one of the most impressive spray lubes I have found is Break Free CLP, 40-60% PAO and other additives. The best has been SprayOn's LU728 with PTFE and a really high flash point. The hard part is finding where to buy it.
Anyhow, I was just wondering if anyone else had any similar experience, recommendations, etc.
Thanks
