That would most likely be cause for me to replace . From your pics it doesn't look like the tire has lots of tread life left on it anyway.I was doing an oil change on my daughter in law’s car and noticed her worn Dunlop front tires had cracks and luckily I spotted them. She will get new Cooper tires tomorrow at Tire Kingdom.
How serious are these cracks ?
She's tearing up the curb scrubbers.
Look at that tire wear on top. Might need new tires and an alignment anyway. Otherwise, PSI isn't checked enough and tires aren't rotated often enough.
DOT date?
DOT date?
I need to check date, but the car is 2 years old with 38K miles.
I asked and she said tires were never rotated.
Many (front wheel drive) cars chew up the front tires if not rotated. It looks like she has one of those. Those tires need replaced....not because of the cracks.
Got a new set of Dunlops. The old set were worn to the treadwear marks. I've never seen cracks on the sidewall before. Chalk that up as another BITOG moment.Those tires are done! For more then one reason. I'd replace ASAP.
Serious enough I’d replace the tire/sI was doing an oil change on my daughter in law’s car and noticed her worn Dunlop front tires had cracks and luckily I spotted them. She will get new Cooper tires tomorrow at Tire Kingdom.
