I have a question that i cannot seem to find an answer to. I have a Massey Ferguson 135 with the Z145 Continental gas 4 cylinder engine. I want to remove the old oil canister and rod and install a fitting into the hole and then be able to purchase a screw on oil filter that would be wide enough to match the dimension of the canister housing over the rubber seal. I found an adapter for 40 dollars but felt that if i could get the fitting our of some motor and install it into the MF engine then all i would need is a cheaper way to get this done. Any ideas would be appreciated.
