Girlfriend's '98 Mazda 626 (2.5L V6, 110,000 miles) has a slight knocking sound coming from the engine. I cannot seem to narrow it down to any particular area. I have never had to deal with an engine that had a spark knock, piston slap, or even pinging before, so I'm not all that familiar with the nature of these sounds. This is one of those "premium is preferred, but lower grades may be used also" type of engines. She keeps putting regular in it. After I first noticed the sound, I told her to switch to premium. She did, and the sound almost went away. Now she's back to using regular (can't "afford" premium - a whole $3 extra per tank, however, there's $120 per month readily available for cigarettes
). Now, I keep telling her that she'll literally blow up the engine if she keeps doing this. Of course, that is only a bunch of BS, designed to "scare her into doing the right thing". What I was wondering about, is what kind of consequences can actually be expected in this situation (if it is in fact spark knock and she keeps using regular) and what would be the timeline.
Can this even be spark knock? Wouldn't knock sensor detect it and the timing would be retarded? There are no apparent driveability issues (aside from things like less than perfectly smooth idle and such, but the way I see it, that should be expected of an engine of this age and mileage).
Should I perform Seafoam treatment, put FP in the tank, etc, or am I way off and this is a different problem altogether?
