This fill of Joe Gibbs LS30 turned into an unintentional Frankenblend when I ran short of top-up oils at two different track days. Apparently, the oil consumption during a track day has increased from 0.5 quarts to 1.5 quarts. Consequently, I wasn't carrying enough LS30 to keep it topped up and ended up putting 1 quart of RT6 and 1/2-quart of VR1 dino 10w30 in it, in addition to 2 quarts of LS30. So with 3.5 quarts of makeup oil added during the OCI, I would expect the oil to still look pretty good.
From Polaris Labs.
7300 miles on oil, 200500 miles on vehicle
Wear Metals
(Element: 193k UOA on RL 5w30, 200k UOA on LS30)
Fe: 103, 33
Al: 16, 10
Cu: 34, 29
Pb: 24, 3
Sn: 5, 2
Contaminant Metals
Si: 21, 15
Na: 20, 40
Multi-source Metals
Mo: 535, 160
Sb: 0, 0
B: 27, 8
Additive Metals
Mg: 105, 252
Ca: 2464, 2624
P: 1076, 1001
Zn: 1403, 1277
Fuel dilution: Soot: Water:
KV100: 10.9 virgin LS30, 12.9 @ 7300 miles
TBN: 10.1 virgin LS30, 3.20 @ 7300 miles
Oxidation: 10 virgin LS30, 23 @ 7300 miles
Nitration: 5 virgin LS30, 14 @ 7300 miles
Polaris Comments:
Oxidation is moderately high. (Yellow caution flagged for being abnormal.)
It's interesting that LS30 is oxidizing in the Camaro. I ran 3 track days on this oil. The oxidation number would probably be even higher if I hadn't added 3.5 quarts of makeup oil. Last year I ran a blend of M1 0w40 and HM 5w30, and got severe oxidation, which Polaris red-flagged. But I didn't add as much makeup oil when I ran the M1 blend, so I can't say that LS30 is more oxidation-resistant than M1. I think what the oxidation readings really mean is that I need to add an oil cooler if I'm going to continue tracking the car. But at 200k miles, is it really worth it?
The really good news is the high Iron and Lead readings of 103 and 24 have dropped to 33 and 3. I think the spikes were caused by the car sitting outside for 3 months during the last OCI waiting for my mechanic to rebuild the transmission. Reference this discussion for more information: http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3074694/1
Viscosity has increased from 10.9 to 12.9, no doubt influenced in part by adding 1 quart of RT6 5w40.
TBN held up well, ending at 32% of virgin. Polaris' practice is to trigger an oil change at 35% of virgin, but I think the OCI could have been longer, considering all the makeup oil that was added. I changed the oil because I wanted to get the Frankenblend out of it, to check on the wear metals, and to put in a lighter 5w30 for winter use. I now have PU in it.
From Polaris Labs.
Wear Metals
Fe: 103, 33
Al: 16, 10
Cu: 34, 29
Pb: 24, 3
Sn: 5, 2
Contaminant Metals
Si: 21, 15
Na: 20, 40
Multi-source Metals
Mo: 535, 160
Sb: 0, 0
B: 27, 8
Additive Metals
Mg: 105, 252
Ca: 2464, 2624
P: 1076, 1001
Zn: 1403, 1277
Polaris Comments:
