Originally Posted By: LeakySeals
Originally Posted By: mechanicx
Good point and not to call anyone out either but LeakySeals didn't really give enough info to really determine what's really going on or what's to blame.
While I maintain that Dexcool is more sensitive to low coolant levels than some other formulas are, I still think it is a great coolant that has a lot of pluses.
Bought the car used at 69k. The dex sludge existed at that time. Whether or not it was changed prior to that is doubtful based on condition. For OAT coolant to be in such poor condition at 69k its bad design, lousy fluid, or both. I've changed Toyota coolant for the first time with 150k on it and not seen anything other than the color being slightly off.
Yeah but over 69k miles and time, the coolant could've been ran low and not topped up, just water was added, or who knows, and this maybe is old rust being beachheaded off. I'm not entirely disagreeing with you that the cooling system setup on these models doesn't keep the coolant totally clear. But as I suggested, unless you have 50-55% quality licensed Dexcool like Havoline or Zerex coolant mixed with perferably distilled water, it's hard to say what's going on. If after that you still have the problem and it bothers you, you could switch to another type of coolant.
Like you said Grand Prixs are nice in a lot of other ways. They're pretty reliable/durable too. Overall, I think they are a good value.
Oh yeah you were using RMI-25. It could possibly be that's what leaving the deposits in the reservoir. Usually if dexcool is causing sludge it leaves a reddish/brown film at the radiator cap and also in the reservoir. I'm not really sure if the percipitants you're seeing in the reservior are the same thing.
