2009 Hyundai Sonata V6 Limited
50,000 miles
I need some ideas on what's going on here.
The heat in the car works normally if the car is started cold, like the first time in the morning, or after it's been sitting all day.
The heat will not work if the car if you start it after it's been sitting anywhere from 10 minutes to 3-4 hours. It also went out a couple of times after a > 5 minute idle.
I want to see if there are some easy fixes I can do on my own before I take it somewhere.
The coolant is full and the temperature gauge reads in the normal range when the car warms up.
Thanks for any ideas!
50,000 miles
